multiple remote wires
just run the remote wire from the HU, to amp 1, and then run a wire from amp 1's remote jack to the remote jack of amp 2.
unless you have really picky amps, or more than 2 or 3.. should be fine.
what I did was ran a remote wire to my component amp, then about 24" before the end of that wire I cut into it and spliced in a second wire that ran to my sub amp. both amps turn on flawlessly.
yep, both are correct. ive done it both ways, and both work fine.
thx everyone for the quick responses!! I knew i could count on the CA.com community!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
now if your amps dont turn on one day (cuz u set both amps remotes to the one h/u one) you'll have to buy a new headunit....so way i see it 5-6 for relay is far cheaper than 100+ for a new headunit cuz you wanted to take the easy way out and fried the remote turn on in the headunit.
i could be wrong but ive never heard of anyone having an issue powering up 2 amps with one HU. in my 8 yrs of having multiple amps ive never had an issue and u are the first one ive ever heard say to do otherwise.
lambofgood91
Closet Niqqa
lambofgood91
Ocala, Florida
wu501
