Multi speaker install
  • 2
flhtci2006
Is this okay:
I'm looking at the Pyle PLRVST400 for my RV.  I have 4 speakers inside the RV and 2 outside.  I also have a Kenwood KAC-6406 external amp.  The Pyle has 3 zones for speakers.  I want to have 1 zone (zone 1) using the Pyle amp for one set of inside speakers and one zone (zone 2) from the Pyle amp for the second set of inside speakers.  Can I connect the Pyle RCA out to the Kenwood amp and have it control the outside speakers as zone 3?  If that won't work, can I connect the zone 3 Pyle speaker wires to the amp or would that overload the amp?
The manual for the Pyle PLRVST400 doesn't identify what zone the RCA outputs are for.
https://www.pyleusa.com/media/custom/upload/PLRVST400.pdf
You can test that to determine and then just label your zones accordingly (for example, Zone A may have to be the exterior if that is tied to the RCA output).
Otherwise, the Kenwood KAC-6406 has high level inputs and, though not ideal, you can connect the amplified output from the Pyle to the high-level input on the Kenwood so zoning works as you intend.
Thank you for the response.  The Kenwood amp does indeed have the speaker levelinputs but, the factory that made the RV did not include it with the unit.  The harness I need is not available as a separate purchase.  I tried thru Kenwood.  As for the Pyle PLRVST400, the really only reason I chose it was it was the size of the compartment it goes into.  We're not audiphiles and in fact we're deaf-ish old people.  We just need reasonable quality.
Pacparts.com sells parts for amplifiers and head units, but that harness is pricey
http://www.pacparts.com/model.cfm?model_id=KAC6406&mfg=Kenwood&back=0&action=list_part
After you test the RCA output that is on the Pyle, you can just revise zone labels as I mention.
Yes, I know of this harness.  Actually it could be purchased thru Kenwood for $55 +/-  but, I can get a new amp for $30 more.  I did purchase a harness for about $6 that is for the KAC-9106.  Looking at the connector as drawn in the manual, it looks the same.  But, thank you.
Hi all, looking to add a pair of speakers to the outside of our caravan. Currently the van has 4 ceiling speakers running off the existing single...
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
105
145
flhtci2006
flhtci2006
flhtci2006
slater
    May 2, 2024
slater
    May 2, 2024
