Mtx Terminators or Kicker comp r 12'
Atreyix
Hey all, as what the title says, what should I get? I'm just starting out in the subwoofer world. What should I get between these two? Dual 12' Subs? (Mtx Terminators) or a single 12' kicker comp r. Kicker would be powered with a 300w rms kicker amp.
Mtx subs will be powered by a 400w rms jvc amp.
I understand there are better ones out there, but between these... which? Thanks!
Links are here
Mtx terminators = here
Kicker comp r = here
Save your money and get something decent, I'd buy used of the forum. You'll spend less and be better in the long run. Something is only new for a bit, and if you install yourself the warranty is probably junk regardless
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
790
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
Atreyix
Atreyix
Wisconsin
Jeffdachef
    May 20, 2024
    May 20, 2024
