MTX RT-X02A xover, and MB Quart 200.72 xover
Funkyskins
When I sold my MB Quart xovers like these, they were Brand new in the box and I only was able to get $40 for the pair, if you can get $30 for both I'd take it!
Usually doesn't, unless it has an adjustable switch for the levels. Do you know what the model of the component set these came from? You could then look at the owners manual for the data.
They were used with Precision Power A404.2 and A600.2 amps. There is no adjustable switch for levels but there are pins labeled 0dB, -3dB, and -6dB. There are also pins labeled biwire and standard. The connects are W-, W+, T-, T+, INH-, INH+, INL-, INL+. Don't know if this helps.
What's the crossover point on the Quarts?
Most MB Quart tweets have a set 3600Hz crossover setting, but it may be slightly different per crossover. I doubt it will vary much between the different passive crossovers since they are intended for use with specific speaker packages, they will almost always be using a very similar or exact same tweeter per series of component sets. The only thing they will be changing is the size of the midbass, with a higher low cut off for smaller sizes or the addition of the midrange speaker. That would bandpass the midbass and maybe raise the tweeter low cross point but not by much since they want the tweeters to handle most of the sound.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
835
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
If you intend to keep the speakers and OEM amp, what's the issue? Did you get the correct harness specific to your equipment needs to wire...
Funkyskins
Funkyskins
Hagerstown, MD
p-funk
maylar
    Jun 2, 2024
    Jun 1, 2024
