MTX Component setup Toyota Pickup Help
David1po
I have a 1990 Regular Cab Toyota Pickup and I got a new deck and a MTX Thunder Axe 4001 4" inch component speakers. It has the sub/mid with the extra tweeter. From what I have been told for best sound I should build a box for the speakers to resonate in instead of the just sitting in the dash. Has anybody done this and if I want to build the box so it sits re-sessed in the dash spot that they have now, how do I do that?
Alright so hopefully when I pop it off mine has one
1.)what do you mean by baffle?
2.)And also are the stock ones good enough? I know for the sub in another car that I built I put it in an enclosed wooden box. Does this plastic work for these higher output speakers?
3.)Where is a good place to position the tweeters? I figure the passenger side, just somewhere in the dash, however the drivers side brings another problem of things, a lot more stuff around.
4.)And lastly with the setup of those MTX Thunder 4001 setup and a JVC KD-R300, do you think I will need an amp?
David1po
David1po
Bozeman Montana
plugitin
