Mtx Amps
  • 4
ALL mtx 2 channel amps (and most other brands) are only bridgable into a 4ohm load according to the manufacturer. anything below 4ohms bridged you are running a risk of damaging the amp!
because when bridged @4 ohms the amp sees a 2 ohm load because you are series wiring 2 channels into 1:p so same thing would be said for bridging into 3..the amp would see half the load due to the wiring thats why i would ask mtx outright....they have great tech support use it;)
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
803
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
289
Montgomery, AL
audiolife
winkychevelle
    May 24, 2024
