MTX amp, P.A.P. amp , COUSTIC line driver/crossover
  • 2
SCIVIC94
if it isnt broke,modify
Up for sale is a few spare amps i am not using.
1st up are some rare Peirce Audio Products amps from early 2000's. this was the only amp they released. they are 4 channels and have been mounted but never in a car.
EMP Series
45WATTS RMS X 4CHANNELS @ 4ohm
90 WATTS RMS X 2 CHANNELS @ 4 ohm
FOOTPRINT IS 10 INCHES X 9 3/8 INCHES
next up is a Coustic xm6 crossover/lindriver
this unit is great for use with headunits that have only 1 set or 2 sets of rca's and you want to run a full system. output single up to 8volts. this also was mounted but never in a car. lots of tuning capability with this unit.
last is an MTX 4160. the way you see you it is how i got it. had it in my truck for almost 2 years. works great. unit is a 4 channel.
20 watts rms x4 @ 4 ohm
40 Watts rms x 4 @ 2 ohm
80 watts rms bridged x 2 @ 4ohms
200 watts dynamic bridges X2 @4 ohms
keep an eye out later this evening will be adding an old kicker zr240 once i get pics.
P.A.P $55 each shipped or $100 for the pair
Coustic XM6 $80 shipped
MTX4160 $50 shipped.
Used to own a 4160 ....****** little amp. What happened to the original mounting feet? Pretty sure they were nylon(material used) and screwed onto the back.
not sure what happened to them how you see it is how i got it. my guess is someone over the course of its life over-tightened the mounting screws and cracked them.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
861
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
SCIVIC94
SCIVIC94
ELIZABETH , NJ
SCIVIC94
