MT Box size recommendations
valin
The King of the North
I am considering picking up a RE Audio MT 18" sub to run in the trunk of my 2000 Maxima SE, but am not sure what box to run with it. I will be running the sub off of a single Memphis Mojo amp. I know the power is a bit low at 2400 watts.
What box size and configurations are you guys running?
I am interested in a combo of both SPL and SQ, and i'd like it tuned low.
Any help would be appreciated.
i dont know if you can fit a box big enough for it through the trunk opening
i would stick with a 15
ive been told for 1 15 a 4.5 cube box with around 90sq in of port works, catch up with ngsm and ask him, i have each of mine in 4cu ft each @34hz withabout 65sq " per sub
you might can stuff a 15 in a 3.5 cu ft box an 18 can do good in maybe 6cube, you can do it lower, but your killing the lowned
i had my 18 in 7cuft @31hz and it had sick lowend, my 15 by it self in the 8 cube box at 34hz has some sick lowend also
valin
valin
Sudbury, Ontario
ZeroGuage
