more the on run of big three..
yes u can but i think u need to double the grounds too? some one correct me if im wrong //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it won't benefit you at all if you don't also double the run of 1/0 to your amp for pos and probably your neg. Most Chassis' won't handle the current that 2 runs of 1/0 can. But let us know your system and how much RMS you plan to pull. 2 runs may not be necessary.
No alternator is going to require 2 runs of 1/0, nor will you see any difference.
You may see .1 or .2 voltage increase due to the lowered resistance, but yeah, nothing worth the cost of the 1/0 wire.
4400 watts rms give or take
4400 watts? Did you get that new Pyle 4400 amp? That thing is a beast. 12x9.5x2.5 Has to weigh at least 8lbs. You can tell it puts out at least rated power by the 3, 30amp fuses this beast requires.
roflcopter //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif why u try that man like that? lol
I would love to be sponsored by PYLE. One of the most respected names in the game. I could just see it now, "Powered By PYLE" across the windshield. Oh and to the OP. If it is the Pyle amp you have a suggest multiple runs of no less than 8awg power wire. A .5 farad Cap is also recommended by PYLE.
if your really putting this into a 1998 mustang i can't wait to see the build, you need to take pics. I put a single 15 sealed into a 1996 (same body) and it was a royal ***** getting it in there, had to take the back seats off completely to the frame, lift the read deck and slide the box into the trunk from the inside lol.
MTX9515
MTX9515
South Subs, IL
GMCJimmyslt2000
