More HP!!!!!
2542 btu's of heat energy per horsepower
500HP 100% efficient motor whould be 1,271,000 btu's of heat energy
most 4 stroke motor aren't heat efficient and are around 40% efficient
so that makes a 500HP 40% efficient motor needs around 3,175,000 btu's
but------- i guess more hp doesn't mean more fuel or heat
gas is 18,000btu per pound
I think we have a winner !!
a KIA? geez. what to do. hmmm, can't sell it, no resale value. can't drive it, not reliable. can't race it, who would make parts for it? so, the only 2 other options is burn it and watch all the pretty colors or donate it to a bum. oh but then the bum would have to pay for insurance. wait, no they wouldn't, no resale value, duh, so it's all good!
name one power adder that adds power without heat-------- if there is such a thing
here goes .................
dropping the "clutch-type"fan and adding a electrical one(new cars excluded here) and adding a set of underdrive pulleys?
maybe not "adding" horsepower, but freeing a few up from drag and if you use a hi-flow fan, and thremostat, couldn't/wouldn't it decrease engine temp?
okay, u can correct me now............//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
changing from a mechincal to and electrical still needs HP--------- except now the HP is needed in the alternator don't think there would be any benifit
1 HP = 746 watts
746 watts / 14.4 volts = 51.805 amps
though i'm not sure of the HP to turn a normal fan at full temp rating
I would think its the same ----- HP
you don't get something for nothing!
okay, u can correct me now............//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif ]
yea your right freeing up HP is good but like you said your not MAKING more--
underdrive pulley work by turn the accessory at a slower speed to lightnen the motors load ----------- good for racing-------- not good for your charging system[lower current output]------ engine cooling[slower cooling flow]----slower everything------- but you don't really have to worry about that stuff to run down the track
it not good to cool the motor too much by low thermostat temps ---------- the CPU was designed too rung the sensors @ normal operating temps--- and may use a different programing if not warmed up fully--------- other reason too------just can think of them right now------i'll look it up tonight
the highest draw fan i could find in jegs was 25 amps. most were around 10amps. not a whole lot of strain on the alt. there.(10 amp one) besides that, isn't this how a elec. fan "adds" hp............
be replacing the mechanical fan w/electric one you reduce drag on the engine. at higher rpms,w/mechanical fan, the engine just isn't fighting internal friction, now it's got to turn a propellor in the wind and it's inherient drag. this is not slowing down the motor, it then compensates by dumping in more fuel to maintain same rpm. when u lose this w/ the electrical fan, you gain/"add" hp. whatcha think?
yes, underdrive pulley's slow everything down, thus requiring less power from the engine to turn the accessiories over. again "adding" hp. 'course with the waterpump slowing down, u could say that that is building/"adding" heat.....push.
what about electric water pump? i know not recommended for street, but?
Originally posted by mrray13 the highest draw fan i could find in jegs was 25 amps. most were around 10amps. not a whole lot of strain on the alt. there.(10 amp one) besides that, isn't this how a elec. fan "adds" hp............
I thought the load was just transfered to the alternator---- though your right---------faster the motor turns-------faster the fan turns- kill HP
and electric one is constant speed------------- so I think you got me
but remember there is still a load-----but on the alternator instead
what about electric water pump? i know not recommended for street, but? ]
who said they aren't for street?----- never heard that---- with them if they fail and you don't look at you eng temp --------you'll get warped heads---
no water flow at all------------maybe that's why they aren't for street
Originally posted by chris229 I thought the load was just transfered to the alternator---- though your right---------faster the motor turns-------faster the fan turns- kill HP
but remember there is still a load-----but on the alternator instead who said they aren't for street?----- never heard that---- with them if they fail and you don't look at you eng temp --------you'll get warped heads---
i got ya? WOOHOO:p //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif just yanking your chain, reading the earlier posts in this thread btween u and spddracer kinda made my "shadetree" knowledge seem..........uh,well..................inadequate. so i had to try! i learned somethings as well though.
as far as the electric pumps not recommended for the streets, i guess it depends on which one u want......we'll call that a push!!
Originally posted by chris229 nitrous doesn't produce "excess heat" it is the increased HP the makes MORE heat. "excess heat" would be seen in any HP adder
Nitrous forces the engine to run LEAN. if it gets too LEAN, you produce insane amounts of heat, and you start melting the pistons to the cylinder walls. A higher flow fuel pump, higher flow injectors, and a new Fuel Pressure Regulator should solve that LEAN problem for the most part. i would advise starting small with a 25 shot, and working your way upto possibly 100, but closely monitor the engine temp.
"First off, nitrous alone will not make you Mustang fly. Instead, it helps you engine make additional power by adding oxygen to the combustion process. Torque (and horsepower for that matter) is created by burning the air/fuel mixture efficiently in the cylinders. When gasoline is atomized, mixed with oxygen, and burned in the combustion chamer, the result is a release of great enery and tremendous cylinder pressure that pushes down on the pistons and rotates the crankshaft. And so, if you can get the engine to burn more fuel and oxygen, it can create more energy and thus more power. To efficiently burn gasoline it takes oxygen and a spark. Only then can we complete the combustion process. While fuel is pumped in by the fuel system, the oxygen comes from the atmosphere and therefore it's less controllable, and that's why it is harder to tack more oxygen in the cylinders. The air we breathe is actually a mixture of 72 parts nitrogen, 23 parts oxygen and about five parts unknown gases. But it's only the oxygen content that our engines use for combustion. If you want to get technical, we'll tell you that for every cubic fot of air, only about 21 percent is oxygen. With nitrous, the percentage of oxygen per cubic foot increases to about 50 percent. That's why some call nitrous "atmosphere in a bottle". To make maximum power, your engine needs to have the correct air/fuel ratio. If the ratio is altered due to a rich or lean mixture, the engine will be less efficient. In extreme situations, an excessively rich or lean condition could result in damaged parts. Naturally aspirated street-type engines operate with appoximately a 14.7:1 air/fuel ratio. However, in racing it's common to have a slightly richer air/fuel ratio, such as 13:1. When a power adder is used, the ratio may be necessary to go as rich as 12.5:1 or lower. That's because with power adders comes increased cylinder pressure and with that comes increased heat. Adding fuel actually keeps the combustion from getting too hoot, which helps prevent detonation. Over the years, there have been great advancement in nitrous technology; however, there are still only a few different ways to deliver the spray to the engine. These systems include dry systems, wet systems, port systems and plate systems. And despite the differences between them, most kits operate similarly. A typical kit will have a nitrous bottle, fuel and nirtous lines, solenoid(s) and either nozzles or a plate to spray the nitrous and fuel into the manifold. Most kits also include electrical connections to energize the solenoids and a switch to activate them. With electronic fuel-injection manifolds, it is common to run a "dry" nitrous system. Having a dry system simply means no gasoline flows through the intake manifold, even though the nitrous is injected at the throttle body. In a dry system, the additional fuel is added through the fuel injectors. This is done to prevent gasoline from puddling in the manifold as it tries to turn the sharp corners found in many stock-type manifolds. Puddling is very bad for two reasons: If the fuel is puddling it's getting to the cylinders, and secondly, is a valve hangs open, the fuel in the intake can explode and blow the intake right off the car. In contrast to the dry system is the "wet" system. Wet systems inject the nitrous and fuel at the same point, usually directly under the carburetor or at the throttle body on tunnel ram style intakes. Wet plate systems are very popular because they are simple and usually easy to install. The third type of system is called direct-port nitrous, the nitrous and gasoline are injectedby a common nozzle mounted directly into the individual ports in the intake manifold, usually at a close point to the cylinder head. A benefit of direct-port nitrous injection is the ability to fine tune individual cylinders. Most of you know that superchargers and turbochargers add performance by pumping air into the engine uder pressure. It's also common knowledge that naturally aspirated engines rely on the negative pressure created in the cylinders to draw the charge of air and gas into the chambers. The beauty of nitrous oxide is that it can add power to any of these engines by adding pure oxygen to the cylinders. The difficult part of adding nitrous is tuning the flow of nitrous and the proper flow of fuel to the engine maintains the proper air/fuel ratio. With today's huge electric fuel pumps, fancy regulators and large lines, we can flood the engine with fuel if necessary. But dialing in the right amount of nitrous oxide is a bit more difficult. Fortunately, there are many levels of nitrous kits available so you don't need a degree in mechanical engineering to get going. Usin nitrous oxide is not rocker science, but there a few basic rules to follow. By now you realize that nitrous has a tremendous and instant ability to produce huge power gains. Nitrous also causes sylinder pressure to rise and with that comes lots of heat. As with any power adder, excessive heat can lead to pre-ignitiong, detonation and severe engine damage. So, let's start with some basic rules of the game. Rule number one is to be smart. Read the instructions and follow the recommendations of the manufacturer or an experienced installer/tuner. Second, use only the spray when the engine is in top running condition and use it in a controlled environment. If you've been driving around on a 100 degree day and the engine is cooking, that's a bad time to make a 20-second nitrous blast, even if it will impress your new girlfriend. Being smart also includes staying aware of your gauges and treating your car with respect. Next, be sure to have the proper octane gasoline. The octane rating determins the gasoline's resistance to detonation or spark knock. Gasoline with a high octane rating burns (or evaporates) slower than a low-octane gas and this is absolutely necessary in the oxygen-rich environment of a nitrous engine. Our tip: if you're using a 50-125 horsepower kit, and the engine timing is set properly, you can get away with 92-94 octane gas. Beyond that we suggest using race gas. Nitrous oxide has great power-making potential, but the "shot" or horsepower level you decide to use must be tailored to the capabilities of you engine. The nitrous used must understand that as power levels rise, the strain on the internal parts increases. Racing engines producing over 400 horsepower will require special preparation. We all know that stock 5-liter engines can handle quite a bit of abuse, but they won't tolerate detonation very long. If you're new to the nitrous game we recommend starting with a small (50-125 horsepower) shot, and then set the timing to 10 degrees (with EFI). With carburation, back the timing off about two degrees per 50 horsepower of nitrous. Thankfully, most 5-liter and 4.6 engines can handle these smaller nitrous kits without any modifications. Still, be smart. Always run the high-octane pump gas and start with a small test squirt. Make a 300-foot run and check the plugs. If they look clean go another 300 feet. Remember, the longer you stay wide open, the larger the load on the engine and the hotter things get. Be patient and finally you'll be running to the end of the track with the juice flowing. (Note: This test can also be done on a chassis dyno.) A burned spark plug electrode is a clear sign of detonation. Another sign of detonation comes in the form of black dots and a greenish tint. A "clean" plug will show light brownish coloration and the electrode will be in perfect conditioin. We also recommend that you check all the plugs, because different manifolds will distribute the fuel and nitrous differently to each cylinder and will cause some cylinders to run leaner than others. And when tuning the juice, always tune for the leanest cylinders. In addition to learning the basic tuning procedures, it's also important to know the limit of your engine's internal components. As you increase the level of nitrous, you must also increase the strenght of the engine parts. While stock rods and pistons will work with a 125-175 shot, a 250 shot normally requires stronger rod and main cap bolts, forged pistons, a stronger crankshaft, and aftermarket connecting rods." 5.0 4.6 Tech Guide", from the editors of "Muscle Mustangs & Fast Fords". If you want more, i can always finish the article, because that's about half of it:)
Originally posted by Moocow16 "First off, nitrous alone will not make you Mustang fly. Instead, it helps you engine make additional power by adding oxygen to the combustion process. Torque (and horsepower for that matter) is created by burning the air/fuel mixture efficiently in the cylinders. When gasoline is atomized, mixed with oxygen, and burned in the combustion chamer, the result is a release of great enery and tremendous cylinder pressure that pushes down on the pistons and rotates the crankshaft. And so, if you can get the engine to burn more fuel and oxygen, it can create more energy and thus more power. To efficiently burn gasoline it takes oxygen and a spark. Only then can we complete the combustion process. While fuel is pumped in by the fuel system, the oxygen comes from the atmosphere and therefore it's less controllable, and that's why it is harder to tack more oxygen in the cylinders. The air we breathe is actually a mixture of 72 parts nitrogen, 23 parts oxygen and about five parts unknown gases. But it's only the oxygen content that our engines use for combustion. If you want to get technical, we'll tell you that for every cubic fot of air, only about 21 percent is oxygen. With nitrous, the percentage of oxygen per cubic foot increases to about 50 percent. That's why some call nitrous "atmosphere in a bottle". To make maximum power, your engine needs to have the correct air/fuel ratio. If the ratio is altered due to a rich or lean mixture, the engine will be less efficient. In extreme situations, an excessively rich or lean condition could result in damaged parts. Naturally aspirated street-type engines operate with appoximately a 14.7:1 air/fuel ratio. However, in racing it's common to have a slightly richer air/fuel ratio, such as 13:1. When a power adder is used, the ratio may be necessary to go as rich as 12.5:1 or lower. That's because with power adders comes increased cylinder pressure and with that comes increased heat. Adding fuel actually keeps the combustion from getting too hoot, which helps prevent detonation. Over the years, there have been great advancement in nitrous technology; however, there are still only a few different ways to deliver the spray to the engine. These systems include dry systems, wet systems, port systems and plate systems. And despite the differences between them, most kits operate similarly. A typical kit will have a nitrous bottle, fuel and nirtous lines, solenoid(s) and either nozzles or a plate to spray the nitrous and fuel into the manifold. Most kits also include electrical connections to energize the solenoids and a switch to activate them. With electronic fuel-injection manifolds, it is common to run a "dry" nitrous system. Having a dry system simply means no gasoline flows through the intake manifold, even though the nitrous is injected at the throttle body. In a dry system, the additional fuel is added through the fuel injectors. This is done to prevent gasoline from puddling in the manifold as it tries to turn the sharp corners found in many stock-type manifolds. Puddling is very bad for two reasons: If the fuel is puddling it's getting to the cylinders, and secondly, is a valve hangs open, the fuel in the intake can explode and blow the intake right off the car. In contrast to the dry system is the "wet" system. Wet systems inject the nitrous and fuel at the same point, usually directly under the carburetor or at the throttle body on tunnel ram style intakes. Wet plate systems are very popular because they are simple and usually easy to install. The third type of system is called direct-port nitrous, the nitrous and gasoline are injectedby a common nozzle mounted directly into the individual ports in the intake manifold, usually at a close point to the cylinder head. A benefit of direct-port nitrous injection is the ability to fine tune individual cylinders. Most of you know that superchargers and turbochargers add performance by pumping air into the engine uder pressure. It's also common knowledge that naturally aspirated engines rely on the negative pressure created in the cylinders to draw the charge of air and gas into the chambers. The beauty of nitrous oxide is that it can add power to any of these engines by adding pure oxygen to the cylinders. The difficult part of adding nitrous is tuning the flow of nitrous and the proper flow of fuel to the engine maintains the proper air/fuel ratio. With today's huge electric fuel pumps, fancy regulators and large lines, we can flood the engine with fuel if necessary. But dialing in the right amount of nitrous oxide is a bit more difficult. Fortunately, there are many levels of nitrous kits available so you don't need a degree in mechanical engineering to get going. Usin nitrous oxide is not rocker science, but there a few basic rules to follow. By now you realize that nitrous has a tremendous and instant ability to produce huge power gains. Nitrous also causes sylinder pressure to rise and with that comes lots of heat. As with any power adder, excessive heat can lead to pre-ignitiong, detonation and severe engine damage. So, let's start with some basic rules of the game. Rule number one is to be smart. Read the instructions and follow the recommendations of the manufacturer or an experienced installer/tuner. Second, use only the spray when the engine is in top running condition and use it in a controlled environment. If you've been driving around on a 100 degree day and the engine is cooking, that's a bad time to make a 20-second nitrous blast, even if it will impress your new girlfriend. Being smart also includes staying aware of your gauges and treating your car with respect. Next, be sure to have the proper octane gasoline. The octane rating determins the gasoline's resistance to detonation or spark knock. Gasoline with a high octane rating burns (or evaporates) slower than a low-octane gas and this is absolutely necessary in the oxygen-rich environment of a nitrous engine. Our tip: if you're using a 50-125 horsepower kit, and the engine timing is set properly, you can get away with 92-94 octane gas. Beyond that we suggest using race gas. Nitrous oxide has great power-making potential, but the "shot" or horsepower level you decide to use must be tailored to the capabilities of you engine. The nitrous used must understand that as power levels rise, the strain on the internal parts increases. Racing engines producing over 400 horsepower will require special preparation. We all know that stock 5-liter engines can handle quite a bit of abuse, but they won't tolerate detonation very long. If you're new to the nitrous game we recommend starting with a small (50-125 horsepower) shot, and then set the timing to 10 degrees (with EFI). With carburation, back the timing off about two degrees per 50 horsepower of nitrous. Thankfully, most 5-liter and 4.6 engines can handle these smaller nitrous kits without any modifications. Still, be smart. Always run the high-octane pump gas and start with a small test squirt. Make a 300-foot run and check the plugs. If they look clean go another 300 feet. Remember, the longer you stay wide open, the larger the load on the engine and the hotter things get. Be patient and finally you'll be running to the end of the track with the juice flowing. (Note: This test can also be done on a chassis dyno.) A burned spark plug electrode is a clear sign of detonation. Another sign of detonation comes in the form of black dots and a greenish tint. A "clean" plug will show light brownish coloration and the electrode will be in perfect conditioin. We also recommend that you check all the plugs, because different manifolds will distribute the fuel and nitrous differently to each cylinder and will cause some cylinders to run leaner than others. And when tuning the juice, always tune for the leanest cylinders. In addition to learning the basic tuning procedures, it's also important to know the limit of your engine's internal components. As you increase the level of nitrous, you must also increase the strenght of the engine parts. While stock rods and pistons will work with a 125-175 shot, a 250 shot normally requires stronger rod and main cap bolts, forged pistons, a stronger crankshaft, and aftermarket connecting rods." 5.0 4.6 Tech Guide", from the editors of "Muscle Mustangs & Fast Fords". If you want more, i can always finish the article, because that's about half of it:)
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif If you condense that, I might consider reading it.
thumpinblazr
thumpinblazr
Middletown, OH
Acidburn
