More Bass
  • 2
TD.....
TEXAS
I'm currently running 2-JL 12WO - 4ohm...125 Watts.....subs, I'm wanting to upgrade to some HiFonics W 124 * Sensitivity: 90 dB * Frequency Response: 30-100 Hz * RMS Power: 300W * Peak Power Handling: 600W * Impedance: 4 ohms......... With the current amp I have will It make a that much of a difference to upgrade subs.
Or will I be better of getting one more JL 12 WO. My ****ing Amp hammers the JL 12's like nothing...........will getting subs with increased watts hit harder. I have a JL Amp Rated Power: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: 95dB below rated power
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Features: Differential-Balanced Input Topology: (1 pair of inputs) On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire +12V and Ground connections: accept up to 4ga. Wire
Now don't get me wrong this **** rocks.........but I need more.
Thanks for any input
No i would'nt in my opinion the Jls are better they are under rated so probally so where near the same wattage as the infinitys as well as you amp. I woudl sell your amp get another w0 and a jl 500/1 amp wire it into a 1ohm load and trust me it will be like a whole nother system it will hit alot harder than it did hope i helped just my opinion. Peace.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
392
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
553
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
716
TD.....
TD.....
TEXAS
jlman
    May 18, 2024
    May 16, 2024
