Kick Panels VS. Factory locations...
  • 3
bt2513
I have a 95 Honda Civic 4 dr. and I am going to install some component speakers up front. Before I do this, I was wondering... because I've heard two different things, what is better? Should I build kick panels to handle the staging or should I mount my woofer in the factory location and then mount the tweeter somewhere above the dash or inside the door near the window and lock controls?? what gives better staging? I've heard that components sound better when they are close together but high end should be coming from above the dash.
BT
kick panels look good as long as they are done right. i would go with some Q-logic custom made one's for your car and NOT build them yourself unless you are a really good box builder or craftsman. i have built about 10-15 custom boxes using everything from fiberglass to just plain mdf to plexiglass. i am telling you this it is a real ***** to build kick panels. i helped a friend of mine put some in his truck for a set of 8in componets and it took forever. just thought you might wanna look into getting some custom built one's through order man look into it.
keep it thumpin,
adam
Hi guys, I am stumped, I own VW transporter T6 SWB van, upgrading at the moment popping in HD600/4, HD750/1,JL W7AE, JL C5 625 3 way in the front...
I'm going to do a wood roof tomo but I don't want a shitty looking interior like most of the ppl I see doing it. What is the best thing to use to...
Mineral wool is another nice dammned good insulation fire proof. Prob same as the Rock wool mentioned. that stuff will last forever
14
Yep. That's exactly what I did. I tried it with my 1/4" flush trim bit, but it didn't leave enough space for the mesh to press the way I wanted...
14
bt2513
bt2513
Raleigh, NC and Wilmington, NC
bumpin_blazer
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
