Mono split to stereo?
cbrrocketrdr
HareFstrVdub
I have an Audiobahn A8000T...its a MONO channel amp.
specs are:
400 watts RMS @ 4ohm load
800 watts RMS @ 2ohm load
now I have a Treo Engineering 15" sub...its a DVC 2ohm...now technically im only allowed to wire the sub to a 4ohm load for the amp to read. but id like to get 800rms...now here's my question. can i run 2 positive wires from the amp positive to each positive coil on the sub and 2 negative wires from the amp negative to each negative coil? my theory is it would still read a 2ohm load and since both coils are hooked up it would split the power, thus putting 400rms to EACH COIL/ 800RMS total to the subwoofer....any input on this? if not possible no biggy i have a DVC 4ohm sub on the way that i can wire to 2ohm load but i wanted to run my treo in the mean time.
In a word, to answer your question, No.
What you're talking about is known as wiring the coils in parallel (wiring both positive coil inputs to a single positive amp output then likewise for the negatives) and will show the amp a nominal load of 1 Ohm when using a DVC 2 Ohm driver.
Best case scenario is that you'll throw the amp into protection.
Worst case scenario is that you'll damage the amp by showing it too low of a resistance.
Here's what you're suggesting doing and this diagram plainly illustrates the result:
alright people thanks for clearing that up...i was almost sure it would be a 1ohm load bc whether i ran + to + on the sub then to the amp or ran 2 wires directly to each + it would prob be the 1ohm load but i wanted to be sure...thanks forum help!
cbrrocketrdr
HareFstrVdub
cbrrocketrdr
Scranton, PA
cbrrocketrdr
