mono or 2-channel
Yes, You just have to wire it diffrently. Look in the wiring and electrical section for a tutorial on wiring the voice coils together.
It says it will do 1000w @ 2 ohms.
It seems as if your best bet would be to only use 1 of those kickers for that amp, if you already own everything, if not look at a new amp.
You're propay going to want something that does around 1500w at 1 ohm. I believe the subs are 750rms and DVC 4 Ohm. So you can wire 2 of them down to 1 ohm. SOmebody correct me if i'm wrong.
15ONE
15ONE
Fresno,ca
kuijo
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
