Mono block or bridge able 2 channel, around 150 RMS @ 4 OHMS
Looking for something a little cheaper, I can buy a cheap -o boss that does 150w at 4 ohms which is perfect for what I need at $55 on amazon, instead of a used. If that sounds unrealistic then idk what else to say.
Boss really isn't recommended on this forum due to its poor quality and their overrated wattages. You would be much better off buying a good, used amp than a boss.
Don't know what you will find something cheaper then 55 bucks.. Most of these amps is going to cost 25-40 bucks just to ship to you.. You might be better off buying that boss amp if you can't fork over a few more bucks..
I was going to say I have a pioneer premier PRS-D2200T which does exactly what you need but go ahead and get that boss amp and waste your time after seeing it wont do what you want if it doesnt completely go up in smoke immediately.
prices are good these days but come on..$55 ? do you really expect it to be dependable?
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
Tis the exact box I am using with my Punch P3 10's wired to 1ohm at the amp. I also have dual terminals on my mono amp. I wired each 4 ohm voice...
14
LongThrow
My Kickers be swaggin'
LongThrow
Springfield, MO
gentlejax
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
