mono block amp quick ?
You can wire the 2 4 ohm subs to a 1 ohm mono amp. That is definitely the way to go
Dont buy two amps and dont buy any shitty kenwood amp either
Check this one out
http://cgi.ebay.com/NEW-08-HIFONICS-BRUTUS-BXI1208D-CAR-AMPLIFIER-MONO-AMP_W0QQitemZ270250788429QQihZ017QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
probably wont do quite rated power but a lot of people that are on a budget like those amps
Or if you dont like ebay
http://sonicelectronix.com/item_12210_Hifonics+BXi+1208D.html same amp $250 plus ship
can all monos handle a 1 ohm load and how would the watts work will it use all the watts of the amp
if wired correctly it will split the wattage between the 2 subs.
no, not all are 1 ohm stable.
i like the hifonics amp you showed me its well in my price range but it says 1200 watt x1 at 1 ohm does that mean both speakers will see how many watts? i might buy that amp if its big enough i need 500 rms per sub
That should do the trick then easily then. Id go ahead and get that one. Both speakers should see 500+ watts on that amp.
dlow265
dlow265
oklahoma city
darkhunter139
