mono block amp quick ?
wire 2 600 watt 4 ohm subwoofers into a 2 ohm load on 2 mono amps. whats wrong with that
Why not just get one 1200 watt amp? Unless you already have them of course. Nothing is wrong with it though if that is what you want to do.
2 kenwood mono block are cheaper than a decent amp that has the same rms output unless you know of a good cheap amp that can put out 5 or 600 rms per channel
Kenwood amps ****
How much do you have to spend on an amp?
oh wait i dont think you can wire 2 dvc subs to a mono and get a 2 ohm load on the amp thats why i didnt do 1 mono i forgot and i wanna spend like around 250
for 250 you can get a nice 1200rms amp.... why are you set on 2 ohm? you could run 4 or 1 ohm...
You can wire the 2 4 ohm subs to a 1 ohm mono amp. That is definitely the way to go
Dont buy two amps and dont buy any shitty kenwood amp either
Check this one out
http://cgi.ebay.com/NEW-08-HIFONICS-BRUTUS-BXI1208D-CAR-AMPLIFIER-MONO-AMP_W0QQitemZ270250788429QQihZ017QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
probably wont do quite rated power but a lot of people that are on a budget like those amps
Or if you dont like ebay
http://sonicelectronix.com/item_12210_Hifonics+BXi+1208D.html same amp $250 plus ship
dlow265
dlow265
oklahoma city
darkhunter139
