Modding amplifiers
The modds can be upgraded internals like what snoopdan did changing out resistors.But making a 1000watt do 2000watts is going to cost more than just buying a 2000watt amp.IMO mods aren't cost effetive enough to justify doing it.
But if you realy want it done I know of someone and can PM you his number.
heres what im looking to do, i have a rockford t20001bd running it at 2 ohms. i want to run it at .5 ohms but it wont take that load. i can get it 18 volts easy with an eclipse 8v with the additional 8v box to equal 16 volts input
You are thinking of the wrong thing there buddy.
When speaking of input voltage of 16-18v, it's speaking of actual battery input voltage on the positive of your amplifier. NOT Pre-out input voltage from your RCA's...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
i misunderstood... thanks for the correction ngsm i can get that kind of regulated voltage with my ho alternator and 3 yellowtops. thats no problem. so modding isnt even worth my time?
How.
It's not worth it. You'd need TWO separate electrical systems. You vehicles stock electronics and wiring will not survive on extended use at 16+ volts...
nG
I gained some on my amps by changing out the thin so called 8guage wires inside and replacing them with 8 guage Knu //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
egg
more current //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif wasnt much of a gain but heck it gained .2db's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
egg
damonhargroves
damonhargroves
Prattville, Alabama
damonhargroves
NorthFramingham
    Jun 30, 2026
