Mobil Enclosures
Nice work on that box. If you paint it, of course, I'm sure you know you will have to fill in the screw holes and seams with wood filler. A painted box, if done right looks really nice. I'm colorblind, so if I told you to paint it a certain color, it might have you all f'd up. Regardless, whether you paint or carpet it, that box will look nice.
just leave it as is, looks good, n well nice work. n yea unmount the amp
ok guys here is what i have so far without paint
anybody have any ideas on some colors to paint it? I was thinking green with flakes to match the exterior color of the vehicle!
Make a side amp rack or throw in a false floor, mount the amp rack to that..along with the box.
wait im confused what do you mean a side amp rack what would that look like? false floor is out of the question due to money issues although I have some left over wood from the enclosure that i might be able to use for an amp rack but I dont know what a side amp rack would look like.
if you put some dampening material between the mounting structure of the amplifier, you can mount it to the enclosure. Not too thick though, some foam material would work good, less than .5" thick. You can mount it to the side of the port, where less compression exists. This will help reduce vibrations a little. What I was thinking, was facing the design to the passenger side, then using the floor area to mount the amp using a secondary sheet of wood with dampening material between the wood and the floorboard. You can secure the wires to the board as well. This is just a simple way to have room for a separate "amp rack" per-say, and not have to worry about it vibrating too much. Compression in the vehicle will not be affect much at higher power levels if the design is coupled well with he vehicle compression area. So, phasing will not be much of a concern, just small changes in output at the listening position. These are two options for you. Not the best options, but for a budget you mentioned, it will suffice.
jchulski20
jchulski20
Jenison, Michigan, United States
Moble Enclosurs
vegang
vegang
