Mk3 Mr2 Custom Enclosure
tarantula_123
CarAudio.com Newbie
6
UK
Anybody out there have a blueprint or spec sheet for building a custom made sub box for an Mr2 convertible/spyder?
Also, what set ups would be recommended, I. E. size and number of subs for that particular box?
Have fitted Boston Pro 60s to the front doors, which will eventually be running off a Boston GT22 which I managed to pick up cheap.
Type custom made sub box for an Mr2 convertible/spyder, in you search engine. Click on images at the top of your search engine. You will get images of various setups for your vehicle. Click on an image that you like, and follow the link. it will usually give you the specifications of the box. Most look like they are .75 cu. ft. for a 10" sub, which translates into 6" high*18" wide*12" deep. Custom boxes can have other dimensions, as long as you wind up with the required volume.
Enclosure for 2 - 10" subs, would be 1 cu. ft. in volume.
.5 cubic feet per chamber
Enclosure for 1 - 12" sub would be 1 cu. ft Volume.
I like the 2 -10" setup behind the seat.
21203
tarantula_123
CarAudio.com Newbie
tarantula_123
UK
huberoy123
vegang
vegang
