I seen a lot of guys fry amps because their back battery was worn down or out with the use of relays and isolators. In fact I know a good friend of mine that bought a used excide orbital to be put in back hooked up to a relay and ran it for over a year without knowing his used battery was basically dead the whole time he used it. He couldn't listen to his system with the engine off:laugh: and thats what he thought a relay did. Had he known wtf he was doing he could have gotten his money back for something that worked. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifEverything audiolife has said is correct. Except for the part about monitoring your equipment regularly, dont do that.
so should i be fine running a almost similar battery up top smaller one...and a bigger one on the back?Dont forget that when we are discussing a front and rear mounted batt setup, the cable adds resistance between the two batts, creating an unequal drain situation anyway (stereo will tend to drain more from closer batt, avoiding cable resistance). And when charging, one batt is clearly closer to the alt than the other, thus experiences less cable resistance and sees more of the charge from the alt.
Keep that in mind when deciding you must have exactly the same batts, even from the same lot number. Things only really get that picky when you have a bank of batts in very close proximity connected via a bussbar, for example.
Someone earlier mentioned isolating the batts via a relay if they are not alike. I do not recommend this, as a relay still connects the two batts together to act as one, creating an uneven charge/drain situation. In this situation, use an actual isolator, leaving the relay setup for someone who has very similar batts.
Both actually //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifDoes a battery make energy or store it? It stores it so it is like a fuel tank right? So lets say you have a 10 gallon tank up front and a 20 gallon in back. Since they are different tanks they have different entry pipes of a different diameter. The entry pipe will equal to a batteries recharge rate as these pipes are what is filling up the tanks. Lets say they had different sized drain pipes to boot. This would be the discharge. With different sized entry and exit pipes and different sized tanks how will they stay balanced?
The chemical reaction inside the battery does give it a very slight charge.How do you figure that a battery makes energy //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Enough to power your stereo without having an an outside source? If what you are saying is true to the level at which it needs why do setting batteries die?The chemical reaction inside the battery does give it a very slight charge.
You asked if they make or create, I said both doesn't mean they can keep themselves charged. If that was the case you would never need an alternator/charger. Hence why I said very slight, as in almost nothing.Enough to power your stereo without having an an outside source? If what you are saying is true to the level at which it needs why do setting batteries die?
o0o I guess the actual creation of said battery matters to the consumer LOLYou asked if they make or create, I said both doesn't mean they can keep themselves charged. If that was the case you would never need an alternator/charger. Hence why I said very slight, as in almost nothing.
