riceboy319
im building my first box and one of the cuts has like a 2 level cut. the first half of the cut is measured fairly accurately but then half way through the cut its 1/16" lower. could i mix some mdf/glue together and fill it in after i assemble that wall? the mdf also burnt from the saw b/c its all blackish brown so sanding it off would be ok? also on the slot L shaped port, its 1/16” smaller (3” to 2-7/8”) after the bend would that be ok? considering i paid for these cuts they didn’t do a good job as every cut was off by exactly 1/16".
