Mini Wall in a Grand prix gt
72hz?
so useless on music then, but i suppose thats the direction you wanted to go considering the volume and port.
would seem more suited to 18s in my opinion.
I am running 2 maxxumis 15" and a xxv sampson.
Mjf that is all the car is for right now is spl. the box is to small for even 15 i need more like15 to 20cu
i know, thats why i said thats the direction you were going in:D
just seems to be a bit much for 2 15s, i would have shot for a lot smaller box if it was me, but, since you're already at w/f i can only assume you know what you were doing:D
wouldnt port into the cab be the same concept as a mini wall, the cab will be sealed completely from the trunk. If the trunk would be sealed from the cabin and ported into it?
somewhat, except it would be more effective and more functional
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
hypnoticguy
hypnoticguy
Oscoda, Mi
hypnoticguy
    May 31, 2024
    May 24, 2024
