mids in sealed pods
niqnak
edit: after researching things alluded to in this thread i think maybe a 3-way system would be the way to go for me if i have things straight. let me know if i'm wrong, but i think i could..
run a tweeter in the stock location in the corner of the a-pillar, run a dome-style midrange in my kickpanels, and run a midbass in a custom sealed pod on my doorpanels
would this work well? and since they would be so much smaller im pretty sure i could better fit custom kickpanels for the midrange or would it really be necessary since they are dome style?
Thanks
Most component mids will do better with more space than what a small sealed pod normally allows for so venting it into the door will probably be your best bet.
you can always add polyfill to the pod. i've found that my mids sound better in sealed pods then in deadened doors.
that was my plan.
my problem is that the stock location is in the kickpanels and its a horrible setup/location and there is hardly any room for custom kickpanels, the ones i have now i wasnt able to angle hardly at all because it took to much space. the doors dont really have any place to put a speaker into, unless i vent a custom pod into the door.
After some searching I am confused on sealing up a kickpod or doorpod with a mid in it. I plan on making some custom doorpods to put the mid of my component set in and I'm not sure whether I should seal it up or not. What kind of airspace does a mid need if its sealed up or is it better to leave some sort of hole in the pod or what? If it matters, I am going to be running a Rainbow Germanium 6.5" comp set.
Thanks
Don't worry about making a pod. Germs, like most car audio designed speakers are designed for IB in mind. It's hard enough stopping door resonaces, let alone the resonsance of a tiny sealed pod built into the door. You'll most likely in end up finding making pods are a total PITA and end up giving you resonances in your midrange frequencies. Just seal up your door well, lots of matting and ensolite, then cover any large holes with plexiglass and mat over them too.
What he ^ said.
ive made pods before and can work pretty well with fiberglass. my problem is that there is no place in my doorpanel for a speaker, the stock location is in the kickpanel so the mids aim straight your feet. the doors are very shallow and the window takes up almost all the room i would have to put a speaker in. i was planning on making pods to attatch to the door panel. i guess i could make pods and try to vent them into the doorpanels..
I would rather build custom kicks than custom doorpods.
I know you said space is limited.....but if you are going to the trouble of "custom"....I would rather optimize the speaker locations in the process.
i knew there was a reason I like you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i have custom kicks right now, they drive me crazy since space is limited anyways and its a manual.
just out of curiosity, are there any mids out there designed to be put into a sealed enclosure?
niqnak
niqnak
Tallahassee, FL
niqnak
