Midbass suggestions...
Hypnoz
IB in the stock door locations.
Am buying a cheap PG amp to power them. should be above 125w @ 2ohm.
Max price must be no more then $160+shipping.
Mounting depth MAX is 2.75"
What i'm looking for is SQL. I want something that will play stuff extremely accurately (for double kicks and such), yet get very loud as well to compliment a single 12" on 900w in a hatch.
I dont really care about high-end extention as they will probably be playing between 40hz-300hz or so.
Pretty specific, i was thinking perhaps the ID-chameleons... not sure how loud they can get, but ID from what ive heard has exceptional SQ.
Anyone else have some other suggestions? Thanks.
All of those mids are 8 ohm which isnt acceptable.
Need 4 ohm...
http://www.diymobileaudio.com/forum/viewtopic.php?t=33
the chameleons can get pretty loud, and have good SQ too. like you said though, they are a b1tch to install. the mounting depth is pretty deep and the magnet is wide. i'm having to use a 1" spacer for mine and it BARELY clears the rear end, and i had to cut the door panel so it wouldnt hit it in the front.
Need 4 ohm...
Do not base your decision off of the impedance of the driver. It is 100% possible that the 8ohm driver could be louder off of the same amp than a 4ohm driver. Impedance does not dictate output.
That said; check those links in that post of mine that Schuey2002 posted. Partsexpress has a ton of drivers, as does http://www.speakercity.com, http://www.zalytron.com, http://www.solen.ca, http://www.meniscusaudio.com, etc etc. Seas, Peerless, Vifa, Scanspeak, Dayton, etc etc....
Hypnoz
Hypnoz
Phoenix, AZ
3.5Max6spd
