Midbass ?'s
As it may be true I have listed only one option thus far, it is also very true that everyone else thus far has not listed any options.
Image Dynamics CX62/CX64
Morel HYBRID OVATION WOOFER 6", SUPREMO SW 6" WOOFER, CDM-88 MIDRANGE,
Genesis Absolute 12m midrange driver
To name a few other options...
why are you naming midrange drivers for a midbass?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
it may be something he may want to look into....
Great advice. He's going to go from a set of entry level PG components to a pair of the best midrange drivers you can put in your car. Makes a lot of sense to me...esp in a thread about midbass.
wow this the dude in the bagged corvette convo in the classifieds....good laughs in their, just an fyi to everyone.
their where? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
FOR MIDBASSES?!
Seriously? a 12m for 50/60hz? Really?
No... REALLY?
I own those mids. I wouldn't cross them any lower than 160hz with a brick wall crossover and never play them above moderate volume. NO WAY would I run them down into the midbass range.
for the record…
midbass does not = subbass playing out of your 6.5’s.
I know. Just wanting to know more about where a good crossover point is for solid mid-bass, as well as what speakers will perform the best.
boom: I understand where you're at, but do you have any drivers in mind so far? What's your budget? And I'm assuming you'll be running a sub, too? In this case, I also assume you'll have the necessary 4-way active processing to make it happen.
I was thinking some ID OEM 6.5's or bigger if they make them, or if someone can suggest another known midbass driver, please do so. My budget is around $150 I can go higher if need be. As for subs, I may run 2 10's, 1000rms to each. I kinda want my substage to be rock solid and very powerful, and have the frontstage still be able to be heard decently clean. As for processing, I was looking at some AudioControl stuff, what would you suggest as far as that goes?
I like that hybrid, I've also heard some good things. Well, I've narrowed down how I want to do this, If I get midbasses more than 6'', they're going in the kicks, and I'll have a dedicated midbass in the kick, midrange in the door, tweets above the midrange. If I buy a driver that has good midbass/midrange reproduction, I'll throw them in the doors, so I have room for my feet still.
boomzilla
Got 'Roids?
boomzilla
Florida
C3 Customs
