Midbass ?'s
Ok. So should I just go a tiny bit above manufacturer recommended specs for the pod?
i personally prefer vented when mids are in the kicks. But some like sealed pods for more puchiness i guess.
Why not have the midbasses in the doors and midrange in the kicks? The further your Midranges and tweets are the better.
Oh, didn't know you meant vent in that way. But I guess I could do it that way too. Once I get all the equipment, I'm gonna move them around the doors to get the best sound for me. Just need help going though it and picking out speakers.
Oh I meant to vent them as to have them act as they are playing free-air. Depending on the driver you choose, you can always make a sealed pod first and vent it after to see the difference... If sealed is preferred you can easily seal it back up.
Either way, I'd suggest dedicated midbass in the doors with midranges in the kicks.
Indeed. With the L8, a sub wouldn't really be needed depending on your listening tastes.
Sweet. I still want a substage though, can't live without some woofers in the back. I run my sub amp on a switch, so It's never on all the time. Basically I would use the midbass to it's full potential while just listening to my fronts, which is what I do at work. I drive for Domino's right now, and there's alot of not-so-good neighborhoods around. Those areas I don't even have my radio on period, but in the better areas I only play my fronts, no need for added attention with bass, ontop of being the pizza guy. And when I'm away from home, I would cut the lower midbass to a respectable level, and turn my subs on.
I believe what he is say, James correct me if I am wrong, is that you would not need to run a sub but if you choose to you can.
with mids that can play down to 20hz... subs are optional //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
boomzilla
Got 'Roids?
boomzilla
Florida
C3 Customs
