Midbass ran as a mono channel set up.
subzero
:confused:I am thinking about buying some subs but there seems to be one problem. each dual coil sub had different impedences. one is 2+2ohms and other is 4+4 ohms. So I am thinking that I can just bridge the amp and run a total load of1.5ohms. What do you think about this idea for midbass....
ok...well I will start by saying that your bridged amp will probley not like to run 1.5 ohms, but only 4 ohms bridged like 90% of all bridged amps.
Next, why would you buy mixed coil subs?
Lastly, can the subs support midbass freqs?
ok...well I will start by saying that your bridged amp will probley not like to run 1.5 ohms, but only 4 ohms bridged like 90% of all bridged amps.Next, why would you buy mixed coil subs?
My amp does bridged at 2ohms.
I wouldnt do this normally. I just saw a good deal on midbass and the catch SO HAPPENS TO BE... the seller only has the 2 ohm coils and 4 ohm coils. and they are elemental design 6 inch midbass.
This is just a what question regarding way it would sound. Thats all.
"I am thinking about buying some subs but there seems to be one problem. each dual coil sub had different impedences. one is 2+2ohms and other is 4+4 ohms. So I am thinking that I can just bridge the amp and run a total load of1.5ohms. What do you think about this idea for midbass....
If it wont sound good having bridged midbass then I am going to pass up on those. So Does the forum members think it wont sound good with mono bridged midbass sound? FYI I would have them in the kicks... Just asking opinions ...
dont do it, each speaker will get a different amount of power.
Let me get this right: You have a sub(s) that are running off of some amp, and midrange/tweets that are running off another amp(s), and you want to add midbass, and bridge those mono? If that is the case, I wouldnt do it. If you need more midbass, just get a decent pair- I have heard good things about id oems, also there is a tang band people ar talking about- and a 2 channel amp, and you should be set.
The way my system is set up is. I have a four channel XTA360.4 and a XTA 360.2 and my mono PA3000db.
I only have 4x6 in the doors ( car is coupe) and I got 6x9 in back deck pushed by the 360.4
The front stage is not loud enough. I want to get some midbass and put them in the kicks and run off the other amp...... ( hence the stupid idea. ) That’s all I was trying to do. I KNOW THE POWER WOULD BE OFF on the mids if I did that. I was just checking to see if anyone had an idea about how it might sound.
So to clarify my decision. I am not doing it. I will keep looking for midbass.
subzero
subzero
Chandler, AZ
cx-7heaven
