Mid bass amp
You need a beefy 2 channel I got 3 aq200.2's for sale this is the specs
Specifications
Model Q2-200
Dimensions 15.8" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Band Pass Filter 20Hz ~ 5kHz
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 220Wx2
2 ohm power @ 14V 340Wx2
4 ohm mono power @ 14V 680Wx1
Power and Ground Inputs
I re-read your original post and it's confusing. Neither wiring option is ideal for midbass speakers. You need them wired separately with left and right signals. Bass is recorded in mono, midbass is recorded in stereo. Unless everything you listen to is recorded in mono you're going to be missing part of the experience the recording engineer intended for us to hear.
They don't sell 2 ohm it's svc so the only way to get them to 2 ohm is if I wire them together in parallel on one channel which isn't good. I think I'm gonna do a 2 channel and just under power them.
it should be fine, those crescendo pwx's are really sensitive, they got loud even on head unit power. Another option would be getting a 4 channel and bridging it for globs of power Precision Power PPI P900.4 (p9004) 4-Channel Phantom Car Amplifier
That was something I was going to try also to remove some of the gasjet from the front
Definitely hard to beat, but they're deep. Didn't know these were still floating around.
13
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
673
gain set well below "Normal" and base boost is off completely
15
DiamondPoint
Surptown
LosIsATool
    May 23, 2024
    May 22, 2024
