Papermaker85
Banned
Between the port and sub broPhase what? Phase at the subsonic? Phase at the port which is summed?
In a vented box at the frequency at which the box is tuned, the port plays and the woofer doesn't. Since the port and the woofer have a direct path to our ears (they are both mounted in the baffle of the box), we hear the SUM.Between the port and sub bro
Does box rise still exist in t-line enclosures?In a vented box at the frequency at which the box is tuned, the port plays and the woofer doesn't. Since the port and the woofer have a direct path to our ears (they are both mounted in the baffle of the box), we hear the SUM.
Dude the port AND the woofer play the woofer is the mechanical resources atrength the port is an acoustical resonator. The woofer is loaded at tuning.In a vented box at the frequency at which the box is tuned, the port plays and the woofer doesn't. Since the port and the woofer have a direct path to our ears (they are both mounted in the baffle of the box), we hear the SUM.
The impeadance changes when the cone picks up vibration from your voice. So yesDoes box rise still exist in t-line enclosures?
Dude the port AND the woofer play. The woofer is loaded.The father you get from tuning the qtc increase and the woofer starts to unload and relies highly on the enclosure. That why a big port limits bandwidth just like a big box.
Wverything has damping. The box port a d woofer. Not to mention the front and rear wave are completely out of phase. The boxes shape tuned and pathway the rear wave travels you try to minimize phase shift and couple the front and rear wave.
This is why any Sq installation utiizes small low tuned ported boxes.
Transmission line work on the principle of the "port" matching the compliance of the woofer and the vent length of the port being that of the FS of the driver stabilizing phase and impedance shifts.
Wtf?The impeadance changes when the cone picks up vibration from your voice. So yes
Coil moves. I don’t understand what the wtf is for.Wtf?You understand why this happens? And that has nothing to do with the enclosure
Tap itCan't see it
Impedance fluctuates when you induce a voltage and current into the magnetic field/coil.Coil moves. I don’t understand what the wtf is for.
---------- Post added at 06:15 AM ---------- Previous post was at 06:15 AM ----------
Tap it
Sorry. Anyway. You will see the port is the source of output at the tuning. That’s why the cone does not moveYou don't know how to do the become like I do in my post? Easier on read
I’m not joking. Put a meter on one and talk beside it. It will fluctuate.Impedance fluctuates when you induce a voltage and current into the magnetic field/coil.
The cone does move. It has to to displace air to move the air mass trapped in the port. At this point the ports impedance is highest. Just like a woofer..Sorry. Anyway. You will see the port is the source of output at the tuning. That’s why the cone does not move
