memphis vs mtx
  • 2
right now i have a jl 300/2 amp with a 12" w3 that hits ok but i want more db i was thinking about going with a (memphis 1000 or mtx81000) and 2 mtx 10" 8000. my friend has a s10 with some crappy amp with 2 mtx 10's and it pounds like crazy, it blows mine away i can hear him coming down the street and the volume is low. i might even keep my w3 and get another one so it will make it 2 but i think the amp isnt doing the trick. also since the jl is a dual voice coil i cant bridge the amp so i'm running it in stereo, i hate dual voice coils. the other day i hooked up my old sub on the other channel and it made my system hit harder and i dont know why. just give me ur opinion, thanks also i plan to spend like $1500
Louis
Try this I'm not sure what impedance your sub is because they come in 2,4, and 6 ohm. But anyhow, connect a + and - from your sub. Then you are left with just one + and one -. Bridge those two wires to your amp. That should help you out some.
If you plan to spend 1500, I would go with something a lot bigger than the mtx 10". Though it is not a bad choice. You might want to consider getting another 12" W3. Then use the amp you currently have JL300/2 to power your hi's/mids, and buy another amp, maybe the JL1200.1. That will leave you with money to spare, maybe for a h/u upgrade.
I would buy another amp with more power for your sub and run the dual voice coils in parallel(++ --) then buy or build a bandpass box for your sub. Use the smaller amp on your fronts. If you dont have an eq you should, make sure it has a x-over also. Then I would buy a Pheonix gold bass cube. Then you should be pumpin! Your box is the most important!
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
soccerguy176
soccerguy176
san antonio,tx
