Memphis tuning ?
  • 4
kizz
omaha, ne
I have 2 10" memphis pr's. Im gonna build my first box for them. I want to port them, where can i get the aero's online? also, i listen to a mixture of rap and rock but my first choice is rock so should i tune them higher or lower? im thinking 1.25 cf per sub. should i do that before or after sub displacement?
hmmm, thats a big box. The manufacturer says 1.25-1.5 per sub ported. I suppose that doesn't mean they wont work well in a big box. Davecubs14, do you happen to know how much power they can actually take? they are rated at 250rms but i cant believe thats all they would take. I have never had a ported box and wanted to try one. I have always had sealed and i just want a lil different sound. Maybe i'll like it, maybe i won't. thanks for the input
They can take more than their rated power. I had 2 12s in a ported box, hit very hard. Pushed about 600 rms to them. Many people have talked about putting around 300-350 to them and being ok.
They do require a big box for ported. I had a 4 cu.ft. box for mine. I messed up the tuning and it was tuned around like....29, ha. They hit pretty hard but they can't take the lows very well.
i have noticed that they don't hit real low but i thought maybe that was becuz of them in a sealed box. My buddy owns a local audio store where i bought these. He recommended that i tune them to 40hz for my array of music i listen to. what do you think about that?
id try the 1.5 ported for the tens 38-40 hz.the pr's do better in bigger ported as stated earlyer.if you go for the 12's sealed you should be able to get away with 1.25-1.5 like the factory suggests.porting the 12's will be 4+ cubes for the pair i was running 3 cubes each at 500 watts each
cool. ok last question cuz i am a noob to subs. going to use port tubes. how do i know what size for 38hz tuning? wat diameter and how long? i think im gonna do 3.5cu foot box for both not subtracting sub displacement. as of now im not sure on exact dimensions but something like 24x14x18
nevermind. found a port calculator. 4" diameter, 4.12" long with a flare port. is that correct? thats really short. thats for 40hz. 38hz is 4.77" long
24x18x14 thats out side dementions right?,comes out to 2.68 cubes,, try 24x18x14.5 outer with 2-3inch ports 8.25 long should be right about 38hz or 2 areo's at 9.375.
those were inside dimensions that i came up with. i have a grand plan of sealing off the subs from the trunk facing into the cabin which might change those dimensions but i don't know if that's something im ready to tackle at this point being a noob to subs. but thanks for your help you have helped a bunch. i like my prs, they sound good altho i haven't heard many other. i have one in a smalled sealed box right now and it just doesn't do the trick yet. gonna get a hifonics amp that does 900rmsx1 at 2 ohms
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
954
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
973
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
4K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
kizz
kizz
omaha, ne
pr-festiva
    May 18, 2024
    May 18, 2024
