Melted Fuse Holder
would this fuse holder be good enough? LINK thanks.
AGU fuses are limited upon rating,and not as reliable as an ANL from my experience over the years being used as main supply..But it will work for you.I dont mind using an AGU inline for amp supply from a solid distro block,but nicer to use Maxi or anl
As Louisina CRX ststed..plastic threads and strip easily over time and get brittle over time due to heat from the engine bay onthe one you posted..work fine inside the vehicle,but not a good concept for the engine bay area
---------- Post added at 07:09 PM ---------- Previous post was at 07:08 PM ----------
what fuse do I need? 100, 150, 200, 250, or 300 amps?
125 max on 8 ga from my experience..
If I upgrade to 4 ga should I opt for the 300?
honda2001
honda2001
texas
tyronekndrck
vegang
vegang
