Measuring rms watts.
Ive done it before with with dmm and clamp.How do i measure amps at 35-40hz. most clamps pick up 50-60.
Clamps? What the hell are you talking about?
Play 50Hz test tone (or whatever tone is in the range you intend to amplify) @ 0db with speakers unhooked, set DMM to AC volts, measure across speaker terminals.
images
Ac volts is gona give me anything.
ac amps and volts i need. Clamp meter is a device that measures ac amps, sound new to you?
People are able to measure at 40 hz and i wanted to find out how.
at 50hz i berely get bass, means that my re curve is high probably and measurement of amplifier output will be wrong.
I'm sure he probably means a clamp on ammeter.
volts * amps = watts
But I'm not sure this is the best way to get the measurements your looking for..
Excuse my ignorance, but won't the load of the sub (2, 4, 8, etc) have an effect on the voltage?
FWIW, I've used a few different clamp on meters at work and some are better than others. Some don't care about the frequency, and I even have one that measures DC amperage.
If you want *actual* watts going to your speaker then you need to place an AC clamp over either the pos or neg of the speaker and measure the AC voltage of that connection with a DMM and play a test tone of your choice (speaker must be connected to cause a load). Amperage * voltage will equal the real watts output from your amp that your speaker is drawing at that volume.
Be sure not to place the clamp over the pos and neg of the speaker wire, as they'll cancel each other out. You won't need more than a standard 70 amp AC clamp unless you're running in the range of 3500+ watts.
Its not hard at all to do and you are on the right track. Dmms can read ac amps but only to usually 10 or so. Any rms clamp meter rated at high enough amperage should do the trick.
But remember that is only a ballpark figure and once a load is hooked up and music is played your 'rms' is completely invalid in the real world.
FWIW try this too: Play whatever tone at whatever volume you want with subs hooked up.
Measure AC voltage at speaker terminals on amp. Multiply that reading by itself and divide by impedance of the subs.
If I'm thinking about this right, that should get you pretty close..
ie:
33 volts bridged 4 ohm load
33 * 33 = 1089
1089 / 4 = 272.25 watts
ie:
33 * 33 = 1089
That wont be close at all.
Speakers are a reactive load and the impedance will change while the woofer is moving. so using the nominal impedance rating of the coil is useless.
There is also box rise which can sometimes add another 1 or 2 ohms depending on frequency and volume.
it is valid! resistence will be off ofcource, Which can measure 40 hz.?
I think you're a little confused. Based off your OP, you want to determine wattage output. You don't do that by measuring hertz (which will obviously be 40 if you play a 40Hz tone). You do that by determining voltage [DMM] and amperage [AC clamp that can read at least 70 amps] going through the speaker wire with a [40Hz] tone playing.
This is something I've been confused about because most of the tutorials out there say to disconnect the speakes, but then the eD tutorial uses a load resistor, I'm so confused. If someone could please clarify this. Sorry //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I like FI
I like FI
miami
I like FI
