Max Speaker Power??
Forget about Max ratings altogether. If it is rated at 90 Rms, that is what you go by. It is possible to get an amp that puts out more than the recomended RMS for the speakers, but you will need to set your gains carefully. If there is doubt on if you can do it, then just stick to the RMS rating.
I agree with Mikey. Honestly it all depends on the speaker. If you got some crap pyle speaker and say somethin like an MB quart, MB quart will handle more than 90 and it depends on how much. just as mikey said, watch your gains. its better to keep them low and be safe than to keep them high and unsure if you're clipping or what not.
Not really. If he has a 60 watt amp that's he pushing into clipping that's actually putting out 100 watts, he may not even get the cooling benefit of full excursion. Just lots of heat with no real cooling. At least if it's a clean signal he'll see full excursion, depending on frequency. Basically overpowered>underpowered.
Edit: NVM, didn't read your post carefully enough, I'm a bit high right now off of bug spray (accident) and it's 2 in the morning.
specialagentPK
specialagentPK
Whitehorse Yukon
T3mpest
