matching uneven ohm loads how can i do it?
95Prober
hi
if wiring (3) DVC dual 2ohm subs together, i can either get a final load of 1.34ohm mono or 3 ohm mono.
now of course the normal amps have a 1, 2 and 4 ohm ratings
in a case like this, what is the best/safe way to correctly set it up??
how will an amp respond? thx
It doesn't have to be a perfect 1, 2, or 4 ohm load. You can put a 1.34 Ohm load on a 1 Ohm-stable amp, but it's iffy as to whether an amp that's only 2 Ohm stable can handle that same load. It either will, or it will go into protect (either immediately, or due to overheating).
95Prober
95Prober
Canada
helotaxi
