Vipervenom18
Like the title states, I'm looking for a 4ch amp for my front and rear comps and a mono amp for my subs.
I have:
-Two pairs of Massive Audio CK6 V5 6.5 comps, 4 ohms, 125w power handling ea.
-Two Sundown SA-12s, wired together for a 2ohm load.
So I need a 4ch amp that will do around 100w x4 @ 4ohms, and a mono amp that will do 1500-1200w rms @ 2ohms.
All of my equipment consist of different audio brands, etc, as most peoples are. HOWEVER, I have a huge OCD that my amps have to be made by the same manufacturer and the same model series. I don't know why.
Considering this, for the best bang for the buck, and knowing it's hard to find mono 2 ohm power, these are the only amps I've seen that match my criteria that are the same model:
WoofersEtc.com - GTO1004 - JBL 600-Watt 4-Channel Grand Touring Series Full-Range Amplifier
WoofersEtc.com - GTO14001 - JBL 1500-Watt Grand Touring Series Monoblock Subwoofer Amplifier
Those two are the same series, and they fit the power requirements, and I can get them for 100 dollars cheaper for each amp elsewhere. The only downside is that they are huge amps.
Any other options out there that I'm not aware of???
Thanks!
I have:
Thanks!
