magnet size.
For a second I thought my post was deleted for some reason. The Assassin killed it in loudness and extension, both low end and high end. Thats about all there is to it.
Then what woofer is it?
Assasins do have power limitations. I'm assuming that has a 3" coil so it can handle a good bit more power and unless the gap is the size of my fist or that ferrite are largely demagnatized that much B-Feild and a few Kw should be able to kick the piss out of anything an assasin could push as far as SPL. Espesically since you are saying high end extension was limiting so it is somewhat safe to assume that is due to inductance which generally means a lot of L in that B-Feild.
Well, it was wired paralell on a Crapti 2000 D, ran each coil with a Hifonics TX1505D, and a long time ago on a Assbahn A2300HCT. Its a dual 4 ohm sub. It got quite loud, but the Assassin was just louder. Its an Audiofonics ADF-292:
Fs - 24 hz
Qts - .4257
Qes - .4692
Qms - 4.5950
Vas - 207 L
Re - 3.2 ohms (dual 4)??? Does that sound right? Thats what the manual says.
Linear excursion is somewhere around 10-11 mm one way.
lukeduke28
lukeduke28
danville
Duke
