Made some 15" SX **** today...
Everything is wired good. Its wired down to one ohm.
It gets plenty loud, just doesnt exurt a lot? But seriously, it has the output that I expected. I used to have an SX.
Electrical isnt perfect, but isnt horrible either.
Ive been watchin other SX vids, and it doesnt seem like mine did bad at all.
alright I have an idea
play the following 3 songs:
Late Night Tip - 3-6 mafia
Ovadose - Twista
Gripping The Grain - Bonecrusher
seriously...play these 3 songs and record your sub.
Gains set flat....volume 3/4 or so
mines goes crazy with 600 wrms....sees full excursion
(3.14 cu ft tuned to 29 hz)
Ovadose - Twista
Will do.
I cant believe nobody understands why its not throwing as far as it can...
A vented box is made to increase efficiency of the subwoofer. This is done by increasing the air being move, and minimizing the stroke of the subwoofer. If you really want to see how far it can throw, pull it out and run it freeair, or build a semi-large sealed box for it.
uhm...mines is vented and moves more than that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
maybe I have a special one...dunno
If yours moves more than that, it either has more power on it or the box is tuned different.
The only way it could be wired wrong and still play is if it were ran in a series, and the amp is not puting out its full power at that ohm load. If that is the case, try wireing it parrallel, it will usually get more than twice the power that way.
I need post a vid up here
tuned to 29 hz (3.14 cu ft box)
600 watts RMS (maybe 700...dunno with these Premier PRS amps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif )
hmmm...........Im thinking it might be the selection of songs
you dumbass, that's why i asked him for the box info in the first place. yeah let's have him run it free air with no air resistance to cushhion the suspension. yeah, that doesn't harm the driver at all //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
DOHCrazy
DOHCrazy
Dallas, TX
PV Audio
