TheePsycho
I'm sorry if this doesn't belong in this section.
I just had my system installed at a local shop that will remain nameless for the time being. I just want to know if the things I notice that they did is something I can really be mad/irritated about.
Well yesterday I just spent part of the day fixing part of the mess the audio shop created in my Jeep Wrangler Unlimited with infinity system. I had them install speakers, dvd navi, satellite radio and a 5 channel amp w/ a new sub. First they put the satellite radio antenna & gps antenna above the radio where the factory compass was. The panel wouldn't close properly and the gps & satellite radio antenna interfered with the factory compass. Had to pop the pannels of the dash to run the gps antenna up to my roll bar and hide it up there. Ended up taking out the satellite radio antenna and relocating the box for the satellite radio behind the glove box and using the stock satellite radio antenna, from the factory head unit. They lost my bluetooth mic and I had to go out and get another one and install that myself. They didn't have any european radio antenna adapters so had to source one and install it (no big deal). They had all the channels screwed up on the Jeep so not one channel was for the correct speaker. I corrected that after a little time with the amp. Found that they didn't listen about how I wanted my sub box mounted, so they drilled the frame like I told them not to do. Then found that they didn't pop the panels to hide the wires for the previous car alarm/remote start they installed and the hard wire radar detector they installed that day, they just pushed them in so they would fall out. I told them where I wanted a button installed for my radar detector and since it wasn't long enough they decided to not lengthen the wires and instead drilled a new hole in a different location. They didn't use my knukonceptz kolossus flex amp wiring kit either because it was 4 gauge and the amp would of only accepted a 8 gauge wire. This could have been solved with a power distribution block as I was planning on upgrading things down the road. They didn't bother calling me ahead of time with any changes which irritates me. I think they put part of my dash together wrong, well I know it's put together wrong I'm just not sure that they did it. Well it was never taken apart before and I doubt it came from factory like that and another panel is missing a pop button to hold it together. Lastly found that they ran wires for the speakers which was good. The bad was that they only partially ran them and decided to tap into the factory infinity wiring harness for the speakers to go the rest of the way. I say it's a half *** job. I guess if you want anything done right you need to do it your self.
I should of done it myself as I know how too, but since I have a baby that is almost 6 months old it is hard for me to find the time to do my own work. But I guess I have to do my own work now anyways as I don't think I want to let them back at it.
So irritated.
So irritated.
