Sold MA Audio HK 4000-D
Magnatus
Banned
AZ
This is a mono amp
Its MODDED! to run down to .5ohms
4000RMS@2ohm
asking 350$+shipping PM if interested
Runs strong and great, i barely use it anymore and could use the money cause im in the process of moving,
Product Description:
* 4000W Digital Class X Competition Mono Block Amplifier
* RMS Power @ 14.4V
o 1800W x 1 @ 4 Ohm
o 3600W x 1 @ 2 Ohm
* RMS Power @ 17.0V
o 2000W @ 4 Ohm
o 4000W @ 2 Ohm
* Temperature, Voltage & Output Level LCD Display
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated Screw Type RCA Jacks
* Double Sided Black Epoxy PCB Board
* Platinum Plated Block Terminals
* Fully Unregulated Power Supply
* Stainless Steel Finish Heat sink
* Quiet Fan Cooling System
* Remote Gain Control
* Full Mosfet Circuitry
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter: 50Hz - 350Hz
* 24dB Subsonic Filter: 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control at 45Hz
* RCA Input Sensitivity: 0.2 - 8V
* Low level Input Impedance: 22K Ohms
* Damping Factor: 200 @ 4 Ohm
* 2 Ohm Mono Stable
* Dimensions: 12.4” W x 2.71” H x 25.86” D
* 2-Year Manufacturer's Warranty
Amplifier Specifications:
* Amplifier Class N/A
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 2000 watts x 1 channel
* RMS Power (2 ohms) 4000 watts x 1 channel
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 8000 watts approx.
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged Not Bridgeable ohms
* THD at Rated RMS Power 0.5%
* Speaker Level Inputs No
* Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - LP
* High-Pass Crossover Frequency N/A
* Low-Pass Crossover Frequency 50 - 350 Hz
* Subsonic Filter 15 - 50 Hz
* Signal-to-Noise Ratio >96 dB
* Channel Separation N/A
* Bass Boost 0 - 18dB(45Hz)
* Bass/Gain Remote N/A
* Fan Cooled Yes
* Fuse Rating N/A
LOL testy. Just trying to help you not make a big mistake. Not sure what Ma Audio HK4000D's you all have but everyone else's HK are not strappable. Just search all of the forums on HK an you will find that all of the posts talk about how they are not strappable. Hey If you think they are go ahead an strap them lol. Call me when they catch on fire.
everyone i've seen has the instructions on the bottom. I'm not sure how it really works, since they don't have master/slave capabilities. Must have to gain match them or something.
Magnatus
Banned
Magnatus
AZ
Magnatus
