Sold MA Audio HK 4000-D
Magnatus
Banned
AZ
This is a mono amp
Its MODDED! to run down to .5ohms
4000RMS@2ohm
asking 350$+shipping PM if interested
Runs strong and great, i barely use it anymore and could use the money cause im in the process of moving,
Product Description:
* 4000W Digital Class X Competition Mono Block Amplifier
* RMS Power @ 14.4V
o 1800W x 1 @ 4 Ohm
o 3600W x 1 @ 2 Ohm
* RMS Power @ 17.0V
o 2000W @ 4 Ohm
o 4000W @ 2 Ohm
* Temperature, Voltage & Output Level LCD Display
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated Screw Type RCA Jacks
* Double Sided Black Epoxy PCB Board
* Platinum Plated Block Terminals
* Fully Unregulated Power Supply
* Stainless Steel Finish Heat sink
* Quiet Fan Cooling System
* Remote Gain Control
* Full Mosfet Circuitry
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter: 50Hz - 350Hz
* 24dB Subsonic Filter: 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control at 45Hz
* RCA Input Sensitivity: 0.2 - 8V
* Low level Input Impedance: 22K Ohms
* Damping Factor: 200 @ 4 Ohm
* 2 Ohm Mono Stable
* Dimensions: 12.4” W x 2.71” H x 25.86” D
* 2-Year Manufacturer's Warranty
Amplifier Specifications:
* Amplifier Class N/A
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 2000 watts x 1 channel
* RMS Power (2 ohms) 4000 watts x 1 channel
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 8000 watts approx.
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged Not Bridgeable ohms
* THD at Rated RMS Power 0.5%
* Speaker Level Inputs No
* Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - LP
* High-Pass Crossover Frequency N/A
* Low-Pass Crossover Frequency 50 - 350 Hz
* Subsonic Filter 15 - 50 Hz
* Signal-to-Noise Ratio >96 dB
* Channel Separation N/A
* Bass Boost 0 - 18dB(45Hz)
* Bass/Gain Remote N/A
* Fan Cooled Yes
* Fuse Rating N/A
Magnatus
Banned
Magnatus
AZ
Magnatus
