THIS AMP IS BRAND NEW, NEVER SEEN POWER!!! RARE AMP HERE! $350 shipped or trade for BIG subwoofer(s) Comes with everything included...bass knob, MA Audio decals, big Chrome metal tag, allen wrench, extra 40a fuses, owners manual, and original box. This amp went for $1k when it first came out.
http://www.mmxpress.com/maaudio/sy7011dx.htm
Class X 1800W Digital Amplifier
The only 1 Ohm Stable Class X mono Block Amplifier on the Market!!! These amps are as serious as they look. Full LCD read out displays amplifier Voltage and Temperature. Two MA Audio Class X amplifiers can also be bridged togehter at 1 ohm to combine their output power. This is another exclusive feature by the MA Audio Class X Amplifiers.
Although the listed Power Ratings have been measured at 14.4 volts, this amplifier is capable of accepting up to 17 Volts DC. This will increase RMS output power by 300W for each load listed below.
SPECIFICATIONS Model SY7011DX
RMS Power @ 14.4V
4 Ohm 750W
2 Ohm 1000W
1 Ohm 1500W
Signal to Noise Ratio >96dB
THD Level
4 Ohm 0.5%
2 Ohm 0.5%
1 Ohm 1.0%
Frequency Response 10Hz - 350Hz
24dB Low P *** Filter 50Hz - 350Hz
24dB Subsonic Filter 15Hz - 50Hz
Bass Boost Control at 45Hz 0 - 18dB
RCA Input Sensitivity 0.2 - 8V
Low level Input Impedance 22K Ohms
Damping Factor 200 @ 4 Ohm
Fuse Rating 40A x 4
Dimensions (W x H x L) 11.6 x 2.56 x 16.73
RMS Power @ 14.4V
4 Ohm 750W
2 Ohm 1000W
1 Ohm 1500W
THD Level
4 Ohm 0.5%
2 Ohm 0.5%
1 Ohm 1.0%
Fuse Rating 40A x 4
