Low Voltage? Please Help!
Nairblop
//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif For some reason or another, I'm only seeing between 6 and 9 volts at the speaker wire terminals with the gain all the way up. I've tried two different amps and still get similar results. This wasn't the case when I was messing with it yesterday. The amps are both 4 channel, speakers are 4 ohms. I tried bridging my JBL P80.4 (160W into 4 ohms) and as I was increasing the gains I was seeing close to 24 volts. Then, my track switched to an 80hz tone, so I kinda jumped to switch it back to the 150hz, and ever since then, I've only been seeing between 6 and 9 volts, regardless of the amp I hook up. What's the deal? Thanks for the help!
Nairblop
Nairblop
Wichita, KS
Atimm693
