low voltage on brand new batt? need some help
Deeper_shades
of underground
I was running a shuriken bt100 under my hood, and it would get up to 14.4v when the car is idling, I decided to add a second batt, I bought a new kinetic 1800 for my trunk and I tested it while running, and it wont stay past 12.11v???? this was with no music, and only my 4 channel amp hooked up. when I start my car it jumps up to 13.5v and than right back down to 12.11v //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
ive done the big three, grounded right off to my frame in the rear, and i have a mechman 150a h/o alt, and 1/0 gauge cable all around.
what could the problem be?
Should charge it up with an agm charger (should be sitting between 12.8 to 13.1 v when it is fully charged) and then check your grounds and fuses. Always before you install a battery charge it or at least see if it is resting at at least 12.5 volts prior to installation. If it was resting higher than 12.11 prior to use I would look at the fuses. grounds and overall installation. The dealer or person you bought it from could have had it sitting awhile without upkeep.
Doubtful though if the battery is resting at 12v + kept at room temps it more than likely needs a charge. I just recovered a few year kinetik hc2400 that was sitting outside for 9+ months resting at under 5 volts, looks pretty spiffy sunfaded and all LOL
turns out it was a bad fuse.......//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
fixed the problem, back up to 14.4v
thanks for your suggestions
Deeper_shades
of underground
Deeper_shades
EH?
Deeper_shades
