Low Pass Filter
ok one more question with low pass at 63 whats your hi pass at 70? cus i was running mine at 125 so i wouldnt blow my mids... but i realize now i gues i wasnt playing any hz from 70-120 where do they go if u set the highpass and lowpass far apart from each other like that?
Crossovers are not a "brick wall" wherein every frequency outside of their setting is stopped dead in its tracks prior to the processed signal being sent to the drivers in question.
Let's take the LP filter for example:
If you set a LP filter @ 63Hz then all frequencies below that are attenuated down at whatever slope the crossover operates at. This doesn't mean everything above 63Hz is taken out of the signal path altogether but rather the....what's the word I'm looking for....we'll say 'volume' of those frequencies is reduced. The steeper the slope of the crossover is (12dB/octave is pretty standard, some crossover use an 18dB/octave slope, some use a 24dB/octave slope, and some have even steeper slopes in use) makes those frequencies being attenuated roll off even more dramatically.
In your example of the LP @ 63Hz and the HP @ 70Hz the frequencies in between 63Hz and 70Hz are going to be reproduced but at a lower volume than everything else.
My HU Xover settings
Low LPF is set to 63 HZ with a 36DB/octave rolloff
mid HPF is set to 75 or 80 with a 12DB/octave rolloff
my MID LPF is set to 2.5k with a 28 DB/Octave rolloff
my High HPF is set to 4k with a 24DB/Octave rolloff.
right now, it sounds awesome, getting about 50 watts per channel.
fnzpntz
Registered User
fnzpntz
TC MI
iamamp3pimp
