Low or high pass filter??? which one??
high pass = let high frequencies pass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif therefore, blocks lower frequencies than the setting.
low pass = lets low frequencies pass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif therefore, blocks higher frequencies than the setting.
Do i use the low or high pass filter on a 4ch amp to run 4 mids\highs speakers? They both show the same specs so i dont know whats the difference between the two?
ANeonRider has it right on the money.
Set it to High Pass. Then set the crossover frequency to just about where your subwoofers are crossed-over.
IE: Subs lowpassed @ 85hz
then highpass mids/highs @ around 80hz Then play with that measurement +/- 10 or so hz to get it to blend correctly with subs.
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
700
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
544
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
loudfivepoint0
loudfivepoint0
Hot Springs, AR
Zerstorer
    Jun 1, 2024
    May 31, 2024
