Low Level Vs High Level
Ok please excuse my ignorance as I am sure people have discussed this before. I looked through the google searches read some things but I am still not sure which one to choose. I come here in hopes of some wise man guiding me in the right direction.
So I have a 2014 Subaru Impreza with an aftermarket HU installed, Pioneer AVIC 8000-NEX. I will be installing my amplifier which is a JL Audio 700/5v2. I have Stinger Speedwire to run in the car. Initially I was going to go the low level (RCA) route but then I was reading more about the different hookup methods and started to become more confused as to which I should install. My overall for this is sound quality. I will be adding sound deadening and a digital sound processor down the road.
I am the kind of person that likes to do things right the first time, even if it's a pain in the butt or costs me a little extra. I will be installing everything myself but I would like to bring it to someone to tune everything because I am not that knowledgeable in car audio as I am mechanically inclined more than anything else. (Unless you guys think that I may be competent enough to do it myself first, and yes, I am familiar with a DMM //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif)But I am willing to learn and educate myself.
So is there no quality difference between the two.
no, not at 4v.
Plus, to use HU sub controls you'd need to use the rca output.
There's no reason to use high level inputs if you're using a good aftermarket HU.
Hi lev inputs on amps were developed for factory HU integration to avoid the need for Line Output Converters. They are not an SQ advantage.
no, not at 4v.Plus, to use HU sub controls you'd need to use the rca output.
Ahhhh, interesting. Thank you for that. Seeing as I would be adding a sound processor down the line I don't want someone to tell me that, "You should have done the high level because of blah-blah and could have gotten better quality." Know what I'm sayin'?
---------- Post added at 01:35 PM ---------- Previous post was at 01:34 PM ----------
Boca/Delray
RCA always
never hi level
Ohhh shiiiz! You go to any of the car meets?
They have cars and coffee at "The Diner" in boynton once a month and then they have the "Kilts and Kars" at the tilted kilt every so often. Then there are the ones that are weekly that all the degenerates go to, including me, that are not sanctioned and get broken up every so often. I've slowed down going to the car meets over the years, as they become a little mundane after a while. Also it's a breeding-ground for rambunctious teens to show off and have near-crashes in the parking lot.
But I use hi level
except , LosIsATool
---------- Post added at 04:11 PM ---------- Previous post was at 04:10 PM ----------
i will be sure not to go
JonTheGreek
JonTheGreek
Sunny South Florida
LosIsATool
Mike Mccabe
