low battery
whojohnjones
my battery voltage wont go past 12.4 vlts with amp power line connected (even with amp off) and after a while my car battery will be low enough so it wont crank everything else will work but wont crank but if i disconnect the line from inline fuse the volts will go up...is my battery too small or what
memphis mcd-1000 amp running at two ohms
Check all of your wiring. I'm running a 760 watt to my subs and an 800 to my doors and it does fine. It sounds like you're losing voltage somewhere so that would be the first thing i checked. After that, it could be your alternator.
whojohnjones
whojohnjones
mississippi
whojohnjones
