loudest box with out sacrificing to much sq on 12 w7?
grimreaper253
ive got two sheets of 3/4 mdf laying around and i want to build a different box. im currently running sealed to jls specs. i want to make it louder with out losing a bunch of sq. should i go with ported with jls specs or is there any other better designs out there? any info would be appriciated.
thanks,
nick
what effect do diiferent port frequencies have? if i went to a larger box would that effect how the bass hits? im gonna build that 2.25 but ill still have some mdf left over so i would like to build another box.
thanks,
nick
Your tuning frequency, Fb, controls the "point" of accentuation. The backwave travels through the port and emerges in phase with the sound of the front of the speaker, which boosts your output. Problem is, you can sacrifice the range of sound, although you typically don't notice it unless you have an extreme tuning. A larger box lowers your tuning frequency with all other factors constant (i.e. increasing the width of the box on one side so the port dimensions and length stay the same).
Actually, that's not what is happening but you're right about everything else.
Ported enclosures boost the response of the sub centered around the tuning frequency. Below this frequency, the response begins to drop. It doesn't fall off right away, but your output begins to drop off.
Increasing the enclosure size will usually increase low end efficiency and can sometimes limit upper frequency extension. Also, increasing enclosure volume will increase group delay which is what often gives the "slow" bass sound and not as nice transient response. This is all sub dependent as well.
Why, what is happening then? The output from the rear of the driver emerges from the port, and it has to be in phase otherwise you'll either get cancellation or delicious comb filtering //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
i would think the wave coming from the back and meeting the front would only be exactly in phase at one freq....since each freq. has a different wave length to it. if you compete and use the 1/4 wave theory, then you only play one freq. because the back of the box is measured exactly, for that freq., to make it in phase when it reaches a given point, usually mic placement, up front.
another way to think of it is air comes out as the sub goes in......
Yes, but I fail to see how the backwave could be out of phase when it exits the port, because the purpose of IB is to isolate the rear wave from the front depending on the baffle dimensions. If what you're saying is true, would you not get loads of destructive interference? I mean, you cannot really be off axis with a subwoofer (yes you can, but the chances of noticing are low), but if you could, wouldn't it be startlingly apparent that something is wrong?
In phase and out of phase are both terms that can mean a number of different things. You're thinking that the physics of a ported enclosure are similar to a transmission line when it really isn't. In order for the rear wave to be in phase with the front wave, it's going to need to travel quite a long distance, even at higher frequencies. That's what's happening in transmission line enclosures. The line length is set to either 1/4, 1/2, or 3/4 the wave length of the Fs of the driver you're using. Ported enclosures do not use 1/4 wave theory but rather, they're based on Helmholtz resonators. At tuning, the enclosure is set into resonance which drives the air in the port to move in and out. This mass of air stimulates the air outside of the enclosure and causes a change in pressure just like the cone of a sub does when it moves in and out.
This mass of air is what causes the majority of output at the tuning frequency. The sub also plays a role as the driving force and also adds to the output. These two moving objects are not going to be 100% in phase with each other. They will also not be 180* out of phase either. There will be a slight delay between the two but the delay will usually be in milliseconds and should be small enough to not cause any audible losses.
If you're still lost thinking that the slight difference in phase would cause all sorts of issues, think about it like placing two speakers directly in front of you but put one about a foot further away than the other. Then listen to music and see how it sounds. Then place the two side by side and play music. See if you could notice a difference. The two drivers would be slightly out of phase from each other by the time the sound reached your ears. It's the same idea here. Now if you placed the two speakers 1/2 of a wavelength and then played that frequency, you would hear a noticeable difference in the sound.
From the 6 boxes I've built, anything above 33hz sounds like garbage. IMO, the w7 shouldn't be made into an SPL sub.
I say around 3 cubes, tuned no higher than 32hz.
Right now I'm at 2.9 cubes @ 27hz and I love it. Though, I'm more into SQ.
Mmm, got it now. I had always figured that the backwave was in phase, otherwise you would have nice DI effects, thus rendering the ported box useless. Ya learn something new every day. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
grimreaper253
grimreaper253
upstate ny
bikinpunk
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
